  • 2 Replies
  • 1896 Views
Crazyb24
I have noticed a potential issue with the Arlo 4 Pro integration with Smartthings (ST). What I have seen is that the Arlo camera appears to be sending motion events to ST even when the motion occurs outside of the activity zone that has been set up on that camera. What ends up happening is that ST triggers an intrusion even though no such event has occurred in the Arlo app.
For example, a flag waving outside of the activity zone is continuously triggering intrusions in ST even though no video had been recorded in the Arlo app.
Has anyone else seen this behavior? If so, any solutions?
I don't use SmartThings.
That said, powering the camera with AC is a workaround.  If you do that, the activity zones are processed inside the camera, and not in the Arlo Cloud.
Crazyb24
Thanks for the info... I did not know that. Unfortunately wiring the cameras is not an option. My expectation is that, even in the cloud, that Arlo only send motion events to Smartthings that occur within the activity zone. Looks like a bug in their integration code. I will have to call support it appears.
