Pro 4 XL-how to set up at second property
We have a Pro 4 XL (3 cameras) setup at our primary home with an unlimited subscription. We would like the same setup at a second property, but the fine print says the unlimited subscription is only good for cameras at one property. So we have to have a second subscription for the second property? If so, how does that work with the app?
Any suggestions appreciated.
While it does say that, it will work fine if you simply ignore the fine print and put everything on one account.
The other option is to create a second account for the other property, which would have its own subscription. Then use the "friend" access feature to share the cameras with your current account.
AppleTV
33 -
Samsung SmartThings
90 -
Security System
