- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Partner Integrations are down at the moment
It appears that partner integrations are down again with Smartthings and IFTTT seems to be impacted as well.
When I review Live Logging with Smartthings it appears that there is a SSL Handshake issue with the Arlo cloud API's
I see these two errors in the live logging which were not there when everything was goodl
[SM] arloApiPost() - Arlo Response Failed. Exception: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: validity check failed
java.lang.NullPointerException: Cannot get property 'presignedContentUrl' on null object @line 2332 (copyClipDataFromArloToSt)
Arlo please work with smartthings and IFTTT to find out what is breaking here.
Yes. I also couldn't connect to my device on IFTTT. Please resolve ASAP. Thanks.
Looks like it is fixed in Smartthings. I haven't checked IFTTT
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
