No connection to Smartthings?
New to Arlo and Smart Things
Have set up 2 cameras so far which worked fine with SmartThings (ST) system.
Everything worked well
Then yesterday both disappeared from ST dashboard.
Tried to add them back as cameras but Arlo is telling ST there are no devices connected!
Both cameras work fine on the Arlo App and the ST system works fine by itself - just not together.
Tried rebooting, deleting and adding them back but nothing appears induce them to connect!
This is obviously a pain as they were purchased as 'the' camera to work with ST!
Everything has the latest firmware updated 2 days ago on installation.
Any ideas welcome
Samsung SmartThings
Hi @JaydenLouis
Please contact the Support Team to further investigate this issue with Smart Things. You will find several options for contacting support in the provided link. Arlo Tech Support
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
