  • 5 Replies
  • 3542 Views
Route66Scott
When I go to Devices > SmartHub / Base Station / Bridge > HomeKit, I am presented with a sheet that states "Discovering your device. Please wait."  Nothing ever happens from there.
After 2 years of not having this feature work, I have discovered that I need a reset to my Pro SmartHub VMB4540, and that this must be done by a moderator.
Please reset my token.
Thank you in advance.
5 REPLIES 5
BrookeN
The token cannot be reset as the basestation is showing offline. Once the basestation is online, please reach back out for the token reset.
Route66Scott
Hello, and thank you for the reply.
My basestation is not offline.
I am able to remotely pull up my live feed as well as locally recorded events using the Arlo Secure app on my iPhone.
Are you using domains related to entities other than Arlo or Netgear to set up Homekit, or to access and update Arlo basestations? If so, please provide them so that I may check my network security software to see if those domains are on a currently active blocklist and correct them accordingly.
Thanks in advance.
Sap3SH
@BrookeN  Can you please help to reset token
same issue - When I go to Devices > SmartHub / Base Station / Bridge > HomeKit, I see "Discovering your device. Please wait."  Nothing ever happens from there.
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
https://kb.arlo.com/000063184
Sap3SH
Thanks, I can now add devices to homekit
