  • 2 Replies
  • 2884 Views
EltonLo404
I can’t find QR code from my base station VMB4540 but I have checked it can be connected to Apple Ho
How can I get the QR code?
Thank you.
There is none.  If you see "Library" in your app menu, you use the procedure with not setup code here:
If instead you see "Dashboard" and "Feed", use this article:
If that procedure fails you can either post back here requesting a "token reset" from the mods, or you can contact support through the support center in the app, and have them do it.
ShayneS
Hi @EltonLo404
Did you still need help connecting to Homekit?
