  • 33 Replies
  • 17514 Views
  • 13 In Conversation
Rob38
Hello!
I lost the ability to integrate my Arlo system with HomeKit. I have completely reset my Arlo and HomeKit systems, removed all devices, and re-added them to my Arlo app. Everything works fine if I use the Arlo app on it's own, but when I try to link the Arlo System with HomeKit through the app, it gets stuck on the Arlo App trying to Discover my system.
Any help would be greatly appreciated... Thank you! 🙂
33 REPLIES 33
amyglen,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
amyglen
Hi There,
No response from cameras through HomeKit again.
Can I please have another token reset sent to my base station?
Thanks,
Amy 🙂
ShayneS
@amyglen
Thank you
ldonlin
How do I request a token reset? My app is still discovering and I can't go forward with the next steps.
Idonlin,
Stevemell
I'm having the same issue. Could I please have a token reset sent to my base station
Baron81
Can I also request a token please? Same issue 😞 spent hours trying to fix
BrookeN
@Stevemell and @Baron81 your token has been reset. You will need to reboot the smarthub/base station.
Baron81
Fixed it immediately!
Thank you!
