IFTTT - record locally?
  • 2 Replies
  • 4697 Views
tsitalon1
Hey guys, I'm using IFTTT to trigger a recording at the top of each hour for a construction time lapse, however the recordings are in my library instead of on my local SD card.
Do you guys know if there is a way to get IFTTT triggered recordings on the SD card as opposed to the library?
note - using Arlo Go 2 (VML2030-1VZNAS)
Manual recordings aren't stored locally - only those triggered by motion.
tsitalon1
Ok, thanks for the reply.
So only choice is to manually download recordings from app/website, I was really hoping there was a method to force local recordings to the SD card... ok, thanks !
