IFTTT connect fails with "Api key is incorrect"
  • 19 Replies
  • 9077 Views
  • 6 Likes
  • 10 In Conversation
bbramsted
Hi,
when I try to connect IFTTT to my Arlo, I get a big red error bar on oauth.arlo.com saying "Api key is incorrect".
Any suggestions?
Kr,
Brian
19 REPLIES 19
NielsV
Same problem here.
Robaaa
I am trying to integrate Samsung SmartThings with Arlo.
When linking my Arlo account in SmartThings and Arlo oauth asks me for my Arlo credentials, I get an error "Api key is incorrect"
Grateful if anyone has any ideas??
BrendenTrory
Does the arlo skills app with Alexa EVER work?
arlo sort your life out or provide free chimes until you can actually write an api that works. It’s embarrassing and I realise how I perhaps should have bought a ring doorbell….
fishinmanfrank
I'm having the same issue.
Stephan905
I am also having the same issue, with both smartthings and Alexa
Stephan905
I am having the same issue with Smartthings and Amazon Alexa. Arlo must be down but the system indicator says that everything is up to date
Stephan905
I cannot connect my Arlo to any services such as Alexa and Smartthings 43kn8sfc4n591.png
pedro_
I'm seeing the same thing; iOS 15.5, SmartThings 1.6.85. I suspect this may be a SmartThings issue ...
Robaaa
Interesting, why do you think it's a SmartThings issue?
  • The issue is when authenticating using the Arlo oauth page, not a SmartThings page
  • User above reports the same issue with Alexa
pedro_
Only because SmartThings has been updating regularly, but I now see that Arlo has also been updating too. So agreed - likely Arlo ... not highly regarded for tech support.
Robaaa
Oh dear. Made a ~$800 investment with Arlo and failing on day 1. I should have been more cautious 😞
pedro_
I'm hoping Matter will improve things somewhat. Until then, I don't think this home automation caper is consumer-ready. It's only for the highly tech-inclined.
Robaaa
True it can be complicated - but authentication is just the basics! Hope this get fixed soon.
Do Arlo support ever reply on here?
curh
I was having issues so I unlinked my Arlo from Smartthings, and when I go to relink it, when on the arlo oauth page, I get an api key error.
ShayneS
Thank you for your feedback, this issue with linking your partner integrated accounts should now be resolved.
Please let me know if are still experiencing an issue.
Thank you
fishinmanfrank
Works for me now. I was actually able to get it working this morning, but I found a workaround myself. I was poking around the SmartThings app, and ended up at the main menu, then hit settings, then went to Linked Services, and Arlo was actually in there, it just showed as Disconnected. Clicked on that, was able to connect it, and everything worked from there.
Stephan905
In smartthings Arlo Cameras with light show up as both a Camera and a light (so the light can be turned on via smartthings). However the light on the Arlo Pro 3 Floodlight does not show up in smartthings.
fridolin2177
For me it is still impossible to connect Arlo to IFTTT. I still get the message "API Key is incorrect". Thanks for your feedback...
ShayneS
@fridolin2177
Are you still experiencing this issue?
