  • 6 Replies
  • 4075 Views
Eyad107
I had to delete my home and start over again
unfortunately I can’t add my base station to HomeKit and it’s not recognizing last time it was fixed with a HomeKit token reset
I need a new reset please
Arlo Pro 2 Pro Base Station Three-LED VMB4000
ShayneS
Thank you
6 REPLIES 6
ShayneS
Thank you
Eyad107
Thank you for your help
I was able to add the basestation and all the Cameras but in HomeKit (Home app) it all have No streaming and says cameras are Off. this is the 1st time i encounter this issue. Do you have any recommendations?
Eyad107
I had to delete my base station since all the streaming is not working and showing as cameras are off
can you reset my token one more time
I do appreciate all the help and I wish there is a way to do my self instead of bothering you every time
Pro Base Station Three-LED VMB4000 Arlo Pro 2
Eyad107
I try to add the base station again now and it showed up in my home and seems all cameras are working and steaming to home app OK now
thank you for your help
ShayneS
@Eyad107 Thank you for the update.
KingBanks
I had it previously connected but it suddenly stopped working. The cameras weren’t responsive in HomeKit but were in the Arlo app. So I deleted the Cameras from HomeKit, hoping to resolve the issue. But when attempting to add the cameras again. It says it needs to be reset. Can someone help with a token reset?
