I removed Arlo basestation in HomeKit after issues with connecting to the cameras. I removed the basestation in HomeKit.
Now when I go in to Apple HomeKit in Arlo app, it searches and searches but can’t find any devices.
Any suggestions?
That solved my issue.
having the same problem..I did a factory reset on the base station, then installed the base station and all my cameras again and I still was having problems with homekit..it worked for like a day got up this morning and the cameras were not responding. I don't want to do another factory reset because my cameras are mounted on my building kind of high. so as of now I'm not even going to worry about homekit.
Hi fredr1k and tbraswell2,
Refer to this article to make sure you're adding your cameras properly through Apple HomeKit: How do I connect my Arlo camera to Apple HomeKit?
Otherwise, contact the Support Team so they can further investigate this issue. You will find several options for contacting support in the provided link.
AppleTV
31 -
Samsung SmartThings
81 -
Security System
