Hello
I successfully added my smart hub to homekit once, but I had to re-do the homekit setup. Now I am stuck at the "Devices found" stage of the hub's homekit section. Reading around the community pages it seems like I need to get a token reset to be able to re-add the hub to homekit. Can you please push one to the hub associated with this account?
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Thank fix
Can I please get a reset token to my base unit ? I have already asked once and got no reply. Need to fix my Homekit after the iOS update.
Hi, looks like I need a reset token for HomeKit as well. Thanks.
Hello could you send a HomeKit reset to the hub on my account as well please ?
I also have an issue with both my base stations. Neither one of them seems to be able to connect to HomeKit. I have read this might require a Token reset. Can you please so that for me?
I am stuck at the "Devices found" stage of the hub's homekit section as well. I've done everything suggested in this thread more than once. Can I get a token reset please.
Could really use some help
I need a token reset. Any help?
I need a token
Your tokens have been reset. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Hello,
I am having issues setting up homekit. It is stuck on "discovering your device". Can I get a token reset please?
Thanks,
I'm also stuck and need a Homekit reset.
Thanks in advance!
I also need my token reset please. HomeKit cannot see either of my base stations.
Can I get an Apple HomeKit token reset
I have two VBM5000 smart hubs and three cameras, but only one camera is available in Apple Home App. I probably also need an Apple HomeKit token reset.
Thank you.
Hi,
Can you please send me a token reset request for homekit?
Thanks!
Hello I need also a token reset!
AppleTV
Samsung SmartThings
79 -
Security System
