Hello!
Can you please send a token reset for the VMB4000 connected to this account. It stopped working after upgrade to IOS18.
Thx in advance.
Br Werner
I could successfully re-add my VMB4000 and cams to Homekit now! Thx for your support.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions
:How do I connect my Arlo device to Apple HomeKit?
My Arlo Hub and cameras are not discoverable on HomeKit either. Please send a new token.
Unable HomeKit connection. Please send a token reset code for my device. Thank you.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
Have powered off and restarted the Hub but still not getting past the “discovering your device, please wait…”
Try logging out and logging back in.
Logged out of the app on both iPhone and iPad. Still not discovering the station…
The only other way would be to do a full reset on the basestation. Please keep in mind that you would need to add back on all the cameras.
@MaxBurner - I don't recommend resetting the base. Lots of posts here from folks with VMB4000s who did that, and were unable to add it back to their account. No idea when that issue will be resolved.
@StephenB it was the other user that had the VMB4000. His token reset worked. Although, looking just now it does appear that he also has a VMB4000.
yes. i have a vmb4000.
but i did only a powercycle and not a full reset of it. after it came back online i could add it back to homekit from within the arlo-app. worked like a charm!
maybe worth mentioning: i did remove the base-station from within homekit at the very start. i only asked for the token reset when i could not add it again…
@werner-k were you able to get the homekit working?
yes thx - see my posts above!
i just marked the wrong reply as answer (mine not yours). and another customer replied with his own request afterwards…
I finally got it all to work after deleting all devices, deleting and redownloading the app, and adding them all back. Naturally, they all need to be on the same network but finding the connected network within Arlo Secure was apparently impossible.
I am glad that you got it to work. If you have any other questions please let me know.
please send a token to my base station for reset
My VMB4000 Base Station is not connecting to HomeKit. Is it possible to send a token reset, please? Thank you in advance.
My Arlo Pro 2 Base Station will not connect to HomeKit. Is it possible to perform a token reset? Thank you.
I too need a token request please. HomeKit just suddenly stopped working.
I too need a token request please. HomeKit just suddenly stopped working and won't connect. Cameras work fine in Arlo app. . @BrookeN
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
