VMB4540 se ha cambiado la camara, esta no aparece en app HomeKit. Hay que hacer un reset del hub salin numero serie A0E20B79A0A44.? Ojo configuración por Verisur.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
Thank's but i can't add to home kit. Home kit see the Arlo base, but i need scan code homekit that i haven't. What can i do?
Did you follow the instructions that were without a code?
AppleTV
33 -
Samsung SmartThings
88 -
Security System
