Hi there.
Will you kindly perform a token reset in order to utilize HomeKit?
many thanks in advance,
Stephen
Thank you
Hello, Could you please also do a HomeKit token reset on my VMB4000r3? Thanks
CraigLindley,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Thank you. That worked
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
