Brandon86,
Are you following to instructions below? At what point do you experience the issue?
How do I connect my Arlo camera to Apple HomeKit?
I have the VMB5000 Ultra kit. (It's not showing the model in the dropdown above). I'm also having the sane issue setting up HomeKit. It sticks in the Discovering your device phase. It doesn't pick up the base station. The base is online and I'm standing right next to it and the router so its not a connectivity issue. I've tried it several times with several different Apple devices with the same result.
and yes, I followed the instructions and verified the firmware was at the correct version.
You may need to remove and factory reset your SmartHub, then add it back to your Arlo account before you can discover it with HomeKit.
Take a look at the discussion on this here: https://discussions.apple.com/thread/8496236
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
