  • 11 Replies
  • 6806 Views
  • 6 In Conversation
Shananwaters
I removed my home base from my homekit and now I new new homekit code to re add
11 REPLIES 11
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Shananwaters
I got it reset but the camera are showing no response in the homekit app. Any Ideas?
BrookeN
I reset it again. Follow the same steps in the link for setting up without a code.
EwwYouStink
Hi @BrookeN,
Could you please reset my HomeKit token as well so that I can reconnect my Base Station?
rahdave_arlo
Please can you reset my arlo base station homekit token
rahdave_arlo
I feel like the Arlo HomeKit token reset should be something built into the app is that something you guys are working on?
BrookeN
@rahdave_arlo thank you for that feature suggestion. I will pass it on to the development team.
Luguang_W
Hi Brooke,
It seems that I am having the same issue. I just bought my VMB4540 and try to add it to the Apple HomeKit. But I don't have the QR code. Can you help me with this?
Thanks!
Luguang
BrookeN
@Luguang_W  I sure can! I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
brymonster
Hello,
I also need my HomeKit token reset. Please help.
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
