  • 6 Replies
  • 3937 Views
IMEko
Like others I'm unable to link my Arlo Base Station with HomeKIt. From what I've found it seems resetting a "token" from Arlo's end is the solution. How do I get them to do that? Their support options are abysmal, I keep going round and round looking for a way to contact them directly and can't.
Posting here works, especially if you tag the mods - @BrookeN , @JamesC , @ShayneS .
They might not respond until Monday though - coverage here is lighter on weekends.
If you have a subscription, you can also reach support using the support center in the app (NOT my.arlo.com).
6 REPLIES 6
IMEko
Thanks, I contacted support via the app.
ShayneS
@IMEko I have reset your HomeKit token, Please reboot your Base Station or Smart Hub and try again.
Thank you
Gazzo
Hello,
@ShayneS I’m having the same issue. Would you be able to send me a token as well?
thank you!
ShayneS
Sure thing @Gazzo
I just reset the token, go ahead and reboot your base and try again.
Gazzo
Thank you @ShayneS
It works now!!!
