Hi,
My cameras seem to have lost their HomeKit Connection. Would you be able to send me a token reset?
Thanks in advance.
Thank you
Thank you
Hi,
unfortunately, HomeKit has not reset. Can I have another token rest to try again?
thanks in advance.
A reset overnight without the base station having power has worked. Thank you.
Can I get this token reset please.
Same here I need a token reset as well
imKevinW, Wyatt381
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Please can I have a HomeKit reset
thanks
Callachd,
AppleTV
33 -
Samsung SmartThings
88 -
Security System
