Google home app doesn’t stream
mohitsb,
Be sure you are following the instructions in this knowledge base article to set up Arlo with google home:
How do I connect my Arlo cameras to the Google Assistant app?
Same problem here. I bought 2 Arlo Pro 2 cameras last week, with the intention of streaming them to my Google Home devices.
Arlo connected seamlessly to Google Assitant, I can see the buttons to both cams on the Google Assistant hub display, but when I click the button or say "Hey google stream _cameraname_ on kitchen display" it says "sorry, it looks like the stream is currently unavailable". Same happens with Chromecast, Google Home Hub and Nest Hub Max. NO STREAM AT ALL. When I tap the button on my phone's Google assistant I get a black screen and says "Not responding".
PLEASE HELP ME, I bought Arlo because it was supposed to be compatible with Google home?!?!
gtrab,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
