Google Assistant doesn't understand commands for Arlo
  • 1 Reply
  • 1735 Views
rickw12
According to a help page here, after connecting cameras to Google Assistant, the user should be able to tell it to "show [name of camera]" on any connected Google device. When I tell it to show the camera on my phone, it doesn't understand.  Is this a question for Google (which could take an eternity to get a response)?
JessicaP
Hi rickw12,
Make sure you have the following compatible Google Assistant devices shown below:
  • Google Home hub
  • Chromecast device
  • TV with Chromecast
  • Media player with Chromecast
Otherwise, you can try rebooting your Google Assistant device to see if that helps or remove the devices from the Google Assistant/Home app and re-add them back on.
If that still doesn't work, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
