- English
- Arlo Forum Discussions
- Partner Integrations
- Google Assistant doesn't understand commands for A...
Google Assistant doesn't understand commands for Arlo
According to a help page here, after connecting cameras to Google Assistant, the user should be able to tell it to "show [name of camera]" on any connected Google device. When I tell it to show the camera on my phone, it doesn't understand. Is this a question for Google (which could take an eternity to get a response)?
Hi rickw12,
Make sure you have the following compatible Google Assistant devices shown below:
- Google Home hub
- Chromecast device
- TV with Chromecast
- Media player with Chromecast
Otherwise, you can try rebooting your Google Assistant device to see if that helps or remove the devices from the Google Assistant/Home app and re-add them back on.
If that still doesn't work, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
