  • 5 Replies
  • 1402 Views
W1ndy
Hi everyone!
I’ve been using both Arlo and Homey for many years, and I know there used to be an Arlo app for Homey that unfortunately stopped working some time ago.
Since I’ve seen quite a few people asking for Arlo support again, I decided to build a new integration from scratch: Arlo Connect.
What started as a small vacation project turned into quite a few days of development, testing, debugging Arlo sessions, MFA, different camera models and Homey integration. 😄 But I’m very happy to finally have something working that I can share with the community.
Arlo Connect is now available for Homey Pro and already supports Arlo cameras, base stations, battery information, motion events, siren control and Arlo modes, with more functionality planned.
You can read more about it here:
https://homey.creson.com/arlo-connect/
If you try it, I’d really appreciate feedback — especially if you have Arlo models that I haven’t been able to test myself. User feedback has already helped me improve compatibility with additional camera generations.
I hope some of you find it useful. 🙂
Best regards,
Mikael
5 REPLIES 5
BrookeN
Thank you for these tips, this will be great information to share in the community.
KimSDK
Hello
Hss there been any changes as I am able to find the Arlo app in Homey - ask it to install - but it never shows in the list of my installed apps in Homey.
Any idea why?
BrookeN
Did you read the suggestions from the user above?
W1ndy
Hi!
I tried to reply on the notification email but that didn't work.
Anyways,
I have 270 installations. Did you try to go to https://homey.app/sv-se/app/com.creson.arlo/Arlo-Connect/
Does it say install?
There are 100 different sites. It's easier if you email me directly.
I also need to know what device you are using and so on.
You find the contact details on https://homey.creson.com/arlo-connect/
Br,
Mikael
W1ndy
yes but thank you for the reminder.
The site doesn't let me reply to the email so my email bounced and I had to login to the site and rewrite my answer.
Would be great if you could reply to the notification.
Have a great weekend.
Mikael
