- English
- Arlo Forum Discussions
- Partner Integrations
- Can’t get Cameras working with SmartThings. Tried ...
Can’t get Cameras working with SmartThings. Tried adding back on but won't add back on.
Hey Guys,
I had 3 Arlo Pro 2 Cameras working Perfect with ST! A few months ago things started to go haywire with the Cameras and ST. I removed the Cameras from ST.
I tried to add them back and just couldn’t do it. I forgot about it till today and decided to remove all the Cameras from Arlo and I also unlinked them Arlo from ST.
I added the Cameras all back to Arlo, disarmed them and then went to ST Device Add. I clicked Arlo, gave ST the credentials for Arlo and it said it was added successfully. But I still don’t see any camera, don’t ever see any cameras to choose to add, nothing! I tried this multiple times deleting everything even the apps.
Is it just no longer possible to add the Arlo Cameras or is there a way to do this that I’m missing? I can’t believe the instructions are not listed how to do this? The instructions I’ve used don’t work.
Thank you very much for any help you can give.
Samsung SmartThings
There is a pinned post on ST at the top of this forum for Partner Integrations where you posted this with instructions.
I can’t believe I can’t get any help on this. I tried on ST forum too.
Hi usmcss,
You should be able to add your Arlo Pro 2 cameras to Samsung SmartThings. You can refer here and/or contact the Samsung SmartThings support team again: New SmartThings Schema Integration for Arlo
How do you clear the cache? Do I just need to reset the Arlo Hub?
I would suggest for you to contact the Samsung SmartThings support team to help you get your Arlo cameras working with SmartThings by emailing to them at [email protected].
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
