Not sure if I have the Ultra or Ultra 2 SmartHub. But it’s not connecting to the Home app. I read something about needing a token reset? How do I get one of those
Best answers
Hi @Ninjja
Thanks for reaching out. At this time, the Pan and tilt camera is not compatible with the HomeKit app. I also see your smart hub is currently deactivated. If you're able to onboard it or bring it online, I can reset the home kit token for you and help you get this set up.
Here's a KB article with more info on the compatibility and how to set up devices in HomeKit: https://kb.arlo.com/000063184/How-do-I-connect-my-Arlo-device-to-Apple-Home
Always useful to know what you have.
There are two smarthub models - the VMB4540 and the VMB5000. There is a label on the hub that will tell you which you have.
Both are compatible with all Ultra cameras. The VMB5000 is usually the one sold with Ultra cameras. It has a microSD card slot on the bottom for local storage (optional feature). The VMB4540 instead has a USB connection.
Hi @Ninjja
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
