Can’t add to homekit
  • 10 Replies
  • 4268 Views
  • 5 In Conversation
sldsnk
I have 2 Arlo Ultra cameras, both in HomeKit and worked fine for years. Today they disappeared from HomeKit. I tried adding them back using the Arlo app, when I click set up HomeKit the app starts scanning for cameras and never finds anything. I tried logging out of iCloud, Arlo and restarted everything and still unable to add them. My Arlo hub and cameras are running the latest software.
Any ideas?
sldsnk
Hi Stephen,
Thanks for the reply. I tried adding them to HomeKit this morning and it worked. No need for a token reset.
Khaled
10 REPLIES 10
@sldsnk wrote:
Any ideas?
Sounds like you need a token reset.
sldsnk
Hi Stephen
Thanks for the help, can you reset my token?
thanks
No, only Arlo can do that (and I don't work for them).  The mods ( @JamesC and @ShayneS ) can do it for you - though it likely will take longer than usual for them to get to it, since it is a holiday weekend in the US.
sldsnk
Hi Stephen,
Khaled
ridgwayk
I'm having a similar issue...was working fine in HomeKit. I changed wireless and added a new Eero 6E and Arlo was not responding. I removed Arlo from HomeKit, and now when I try and add the basestation back it stays on the "Discovering your device" mode and never connects.
sferros
Can I please have a token reset? I can’t add my SmartHub to HomeKit, it just hangs there spinning, or I get the “Unable to add accessory” if I try to add via Home app.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
ridgwayk
The reset token didn't work.  I followed your instructions on removing power, rebooting, and then trying to add the base station.  The screen never changes after it starts searching for the base station.  Please advise.  Thanks.
ridgwayk
I've also opened a ticket with additional steps taken if that helps?
sferros
Thanks @JamesC, all good now, I can now add my SmartHub to HomeKit.
