I’d like to add my base station and doorbell cam to apple HomeKit, it used to work but I had to reset everything and now it doesn’t.
I believe you can send a token to reset the base station, if you could please
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit?
Bumping this up in the hope you can help!
I had already reset the token are you needing it reset again?
Apologies for my post above, I missed your post.
That worked a treat, thank you!
- Need a token reset
Yes
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
