  • 7 Replies
  • 3344 Views
  • 2 Likes
Estwing
I’d like to add my base station and doorbell cam to apple HomeKit, it used to work but I had to reset everything and now it doesn’t.
I believe you can send a token to reset the base station, if you could please
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit?
https://kb.arlo.com/000063184
7 REPLIES 7
BrookeN
Estwing
Bumping this up in the hope you can help!
BrookeN
I had already reset the token are you needing it reset again?
Estwing
Apologies for my post above, I missed your post.
That worked a treat, thank you!
Marlenekennamo
  • Need a token reset
Marlenekennamo
Yes
BrookeN
