Same issue as the others - if I try adding the arlo to HomeKit, it gets stuck discovering. Please send a reset token. Thank you!
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Thank you! Worked a charm and I’m connected to HomeKit again!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
