Also have a few Arlo Pro2 on an older base working perfectly fine with Homekit.
Cwmmmm,
You may need to remove and factory reset your SmartHub, then add it back to your Arlo account before you can discover it with HomeKit.
Take a look at the discussion on this here: https://discussions.apple.com/thread/8496236
I have a VMB4000r3, on firmware 1.16.1.1_3348_facf74c. I have a few other devices on my Apple homekit, with an Apple TV4K as a hub. My VMB4000r3 is attached by ethernet to my router/firewall, and my apple devices have a firewall rule allowing any connection. The Arlo article on homekit under support indicates that I must be on the same WiFi network as the base station -- which is impossible, since the base station must be attached with ethernet, and the WiFI component is inaccessible to me (an issue for another time).
The Arlo app's response to setup for homekit is to continuously search for devices, and never finding one. There is no homekit code on or in my original box. Thus, no homekit availability for my Arlo base station.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
