- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Stil got network failure message om google hom...
Hi Mikemac12,
Have you tried re-pairing your Arlo account to Google Assistant to see if that helped?
Hello!
can anyone help me?
I have installed my cameras and successfully connected my arlo to google, all cameras is showing on my google home application i n my iPhone but when i try to open the cameras to look at them live i get the network failure message saying the camera is not connected to my wi-fi.
anyone got the same problem our do anyone have a solution to this problem?
Can the iPhone get into the Arlo account?
Is it just the "live" bit that doesn't work?
Just another user
The arlo app is working it's just the google home assistent app that's not working
Hey Andreas1986,
Have you tried re-pairing your Arlo account to Google Assistant to see if that works?
Hey Mikemac12,
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
AppleTV
31 -
Samsung SmartThings
81 -
Security System
