  • 10 Replies
  • 3270 Views
  • 3 Likes
mm1233
Hello, when I open arlo app it says I have to update it, but when I try to do that i can’t because it shows like it is already updated. I can’t use the app because it says it must be updated.
Thanks for the answers.
JessicaP
Thanks for those images. Have you tried updating or installing the Arlo app for your Amazon device through this link: Arlo [For Amazon Devices]?
10 REPLIES 10
mm1233
@mm1233 wrote:
The app is on amazone store*
Try just installing the new app (the old one was from Netgear one, the new one is from Arlo).
It's possible you'll need to remove the old one prior to installing (I don't own a fire tablet, so I can't try it). But with Android it was possible to install them both.
mm1233
I have already tried this and it still doesn't work. I have a Amazon Fire 10 tablet.
Maybe I have to wait for an update?
JessicaP
Hi mm1233,
Could you provide screenshots that shows that the Arlo app on your Amazon device needs to be updated?
mm1233
The first photo shows the app when I open it. The second photo shows what happens when I click on it ( google play store and it says that it is installed)
The third and 4 photos are showing arlo app in appstore (from amazon)
thank you!
mm1233
mm1233
mm1233
JessicaP
mm1233
