- English
- Arlo Forum Discussions
- Partner Integrations
- Arlo app adds more cameras then I have setup in Ho...
Arlo app adds more cameras then I have setup in Homekit
Hi there,
I purchased a 3 Pack Arlo Pro 3 with Smarthub from Costco. I moved two existing Pro 3 cameras that I have to the new SmartHub as they didn't reach the main SmartHub in the house from the garage. When I add the new SmartHub to Homekit it adds 3 more camera's on top of the existing 2. I know that the pack comes with 3-Pro 3 Cameras but I am looking of using those at the Cabin with an existing SmartHub that I have there. How do I remove these 3 no response camera's from the Home app?
Hi Mad90,
Try the following steps to see if this helps:
- Launch the Arlo app.
- Tap Settings > HomeKit.
- Select a device under DEVICES ADDED TO HOMEKIT.
- Tap Remove Device at the bottom of the screen.
- Read the pop-up banner.
- If you’re sure you want to remove the device, tap Remove Device.
The device is removed from HomeKit.
You can also refer to this article: How do I manage HomeKit settings in the Arlo app?
AppleTV
32 -
Samsung SmartThings
84 -
Security System
