Arlo VMB400 - Can’t add to HomeKit
I am not able to connect my Arlo pro VMB4000 to HomeKit. The base doesn’t have QR code and when I try to connect to HomeKit via the Arlo app, it gets stuck at discovering device and nothing happens. The VMB4000 is connected via Ethernet cable and I’m on the same network on my cell phone. Please help!
I have the same problem and need a token.
myarl0, Cribbe8
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Thank you. That worked!
Thank you. Works now.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
