- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo Pro 2 mic capabilities through Smartthing...
I recently set up my arlo cameras on my Smartthings app and wanted to verify whether I did so improperly or there are limits to the integration.
1) The two way features that allows me to communicate from my phone (using the Arlo app) is grayed out when I use the camera through Smartthings (screenshot attached).
2) Can I actually change modes, such as disarmed to armed vis Smartthings or do I need to do so through the Arlo app itself?
Any clarification would be appreciated.
Please contact the Support Team regarding this inquiry. You will find several options for contacting support in the provided link. Arlo Tech Support
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
