Arlo Pro 2 Not Connecting to HomeKit`
I have the Arlo Pro 2 with VMB4000 base. When attempting to connect with HomeKit, I keep getting the white page that states, "Discovering your device. Please Wait."
I've waited more than 30 minutes, and nothing happens.
It also states, "Make sure your Arlo Camera is powered on and nearby."
I am sitting right next to the base.
And "Check that you have the late firmware version in Settings > My Devices > Device Info > Firmware."
There are no updates available.
Any help is appreciated. Thank you!
Sounds like you need a token reset. I've tagged the mods - @BrookeN , @JamesC , @ShayneS - as they can do that for you.
Thank you
Hello ShayneS.. can you also reset my token? Same issue.. many thanks!!
Jeff
@Twistedneck
I have reset your HomeKit token as well, Please reboot your Base Station or Smart Hub and try again.
Thank you
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
