- English
- Arlo Forum Discussions
- Partner Integrations
- Arlo - Live view not supported on this device (Ale...
Arlo - Live view not supported on this device (Alexa App)
Hi Arlo Community, Live View works on my Echo devices but does not work with my Alexa app, I have a couple of Pro 4 and Essentials, and none seem to support live view in the app. Any suggestions on how to fix? Note I have removed and installed the skill twice and also removed and discovered the cameras three times to no avail. Thanks in advance
ricardogordon1,
If it's working on your Echo devices, it sounds like you have it set up correctly. What happens when you try to live view in the app? Do you receive a specific error message? Do you have any trouble live streaming with the Arlo mobile app?
Hi James,
Thanks for your response
The Arlo app works perfectly with no issue, but within the Alexa app (Android I haven't tried it on IOS) I go to Devices > Cameras and see the message on all Arlo cameras "Arlo - Live view is not supported on this device" I am running Android 13 & Android 12L, so the latest versions
Hello,
Have you been able to figured this out yet? I am having the same trouble and nothing I do works. I have the Arlo Ultra cameras with the base station VMB5000r4. Maybe the base station isn’t compatible? Thanks for any ideas!
Still no luck, working with Alexa support but their advice to uninstall and reinstall the skill did not work, ticket has been escalated I will let you know if I get resolution, good luck!
Thank you! I’m going to keep trying too. Hopefully one of us can figure it out!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
