- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo-Google Assistant “Something Went Wrong” E...
Hello and thanks in advance for your help!
I am running into what seems like a common issue integrating Arlo and Google Assistant/Google Home. When I follow the instructions in the Google Home app to set up a device Arlo shows up as a non connected service and when I click to set it up I get a brief message that says “Arlo linked” followed by another message that says “Something went wrong. Try Again”. The Arlo app is never opened to “authorize” the connection.
Because I have multiple Google accounts signing into my phone, I can select a different email address from the upper right hand corner of the Google Home app...when I select any of my other email addresses I am taken to a “new” & empty google home where I can successfully add the arlo connection. The Arlo app automatically opens to a screen to authorize the connection. Strange, right? It appears to be some sort of issue specifically with my primary google account.
To date I’ve been unsuccessful with working with Arlo support... I’ve deleted both the Arlo and Google home apps from my phone, reset the arlo base station, restarted the phone, etc. It’s the same situation and same pop ups each time.
I’m using an iPhone 11 Pro version 14.6, the Arlo app version 3.2, the Google Home app version 2.37 and the Google Assistant app version 1.9.20109.
Thanks in advance for any help y’all can provide!
This was an extremely frustrating experience and I’m sorry I can’t replicate my solution exactly for you, but I hope this helps as an experiment to try.
Hi claydog,
You mentioned you contacted the support team on your post. Let me reach out to you via private message to gather more information from you.
I am using Arlo Baby and have iPhone 12
Hi prues,
Have you rebooting your Google Home device to see if the issue still happens?
You can also try removing your Arlo account from your Google Assistant account and re-connect it again. You can read here to learn how to re-add it back on: How do I connect my Arlo cameras to the Google Assistant app?
Hi cmaxwell538,
Have you tried the troubleshooting steps shown above?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
