Arlo Cameras not displaying on Sony Bravia TV. Synced with Alexa.
  • 1 Reply
  • 3130 Views
JVM1120
I bought a 4 camera Arlo Pro 2 set and installed it earlier today. I have a Sony Android TV , Amazon Alexa dot, and an Amazon Firestick that is the 4K version. I added all the devices to the Alexa app and enabled the Arlo skill. I also set up my Sony Bravia tv to sync with Alexa. When I ask Alexa to display a certain camera I see a message that says "Waiting on Arlo" then the screen closes. Or The camera will take a while to load and display briefly before closing. Is there a way to get the cameras to show up consistently and load quicker?
The cameras display fine while using the app.
JessicaP
Hi JVM1120,
Have you try disabling and re-enabling the Arlo Alexa skill to see if that helps?
