- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo Baby not working with Amazon Alexa Show
Hi,
I have been using my Arlo Baby on my two Alexa Show devices in my home and the connection will no longer work. I have tried many different things such as resetting devices on both ends, disabling the feature on my Alexa and then enabling, etc ...
This used to work with no issues on my Alexa devices.
Please let me know if there is any way you could help me.
I never did enable 2 factor authentication on my Arlo account, but I just disabled and enabled the Arlo skill on my Alexa account and it seems to be working again.
Hello community,
Are you still experiencing this issue with your cameras & streaming with Amazon devices?
After I can get it to connect, it is now working again. Of course, sometimes it connects on the first try and sometimes I have to try over and over again to get it to connect using the Show. Connects every time using my phone. Progress, I guess...
Interesting... I may need to pull mine out of the closet, dust it off and give it a try again.
It's been working for me over the past week. I recently turned on the 2 factor authentication and it seems to still be working so far.
Hey Shayne - So Echo Show 5 worked intermittently with the Arlo Baby, if at all. NOW, since I did what was suggested...remove the skill from Alexa and turn off (or turn on/then back off) 2-step authentication and that seems to have worked. HOWEVER, the monitor sits next to my bed so we can watch the baby all night and not once has the monitor still been on when we wake up. So, at some point in the night, it shuts off and thus we're not longer monitoring our child. So, we seem to have made some progress with the camera showing up on the Show when prompted, and it does stay on a reasonable amount of time if you were needing to monitor for an hour or so. We just need it to act like a monitor and I know the Amazon technology works with Arlo Baby because we use the Fire Tablet 7 as a monitor, but we want something that will stay in our bedroom and that's what the Show is for.
Hi @Ltscam
You can view streams from your Arlo camera for a maximum of 30 minutes. If you view a stream for longer than 30 minutes, the Arlo app will stop streaming. To resume the stream, simply press the play button again.
The 30-minute streaming limit is implemented to avoid potential problems when a stream is accidentally left active.
Please find the following article here: Why has the Arlo app stopped live streaming?
This issue should now be resolved after a recent server update. If you still experience this issue please contact Arlo Tech Support
AppleTV
Samsung SmartThings
79 -
Security System
