- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Apple HomeKit stuck at "Discovering your devic...
Finnoy,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Finnoy,
If you're still experiencing an issue, you may need to remove, factory reset, and re-onboard your base station.
Take a look here for more information on how to do this: https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-Base-Station
Finnoy,
I've sent another token reset.
I gave it a couple of days to process the token just in case, but the problem is still there. It gets stuck when I press "Homekit"
Finnoy,
I encourage you to reach out to the Arlo support team to further investigate the issue. You can find support contact information within the Arlo Secure app under Settings > Support.
Could you please send a token refresh to my SmartHub also, having the same issue. Thanks.
BenjaminCole,
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
