- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Apple HomeKit stuck at "Discovering your devic...
I had HomeKit set up but then removed it because I was reorganizing things. Now when I try to add my base station again the app just gets stuck on "Discovering your device. Please wait." I saw this posted elsewhere for a different hub and support sent a token reset request which seemed to resolve the issue for others. Is that what I need here?
Apple Homekit stuck at "Discovering your device. Please Wait“
Can you please send me a reset token request ?
Moreover, it’s absurd that this requires a support intervention? Will there be a firmware update that fixes this bug?
Thanks,
Michael
I added my cameras to HomeKit a while ago, and everything seemed to work. Since last week, all the cameras show No Response in HomeKit. The cameras work fine in the Arlo app. If I go to the HomeKit Set up in the Arlo app, the app doesn't go past the Discovering your device page, with the gear spinning next to DEVICES FOUND. Any suggestions?
I require a token reset. How can I request this?
Will you please send a token reset request to my base station?
I need to have the token reset on my Arlo bases. They were connected to apple homekit and then stopped working. When I try to add them it sits at the discovering page on my iPhone and does nothing.
Same issue
Hi barlo, apnshirt, Brianh2021, jwj2, mluisbrown, AndreaNY, bobadelle, smytperformance, Knappster22, Grakson, Zzyzx,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hi SRaga,
I need a token reset for my hub as well (had to reset Homekit setup). And will this capability (e.g., self-service reset) be added to the app or web portal at any point in the future?
Hi sg6,
Thanks JessicaP! Resetting the token worked.
Thanks JessicaP, the token reset worked.
However, could you please answer some questions about this issue?
Why is this token reset required? As the person doing the token reset requests, you must be more aware than anyone that requesting resets via the community forums is not a solution that can scale.
Are there any plans for a firmware update to fix this issue?
Thanks,
Michael.
Hi Olafant,
Hi - Am encountering the same issue as described on this thread with my setup. Are you able to assist?
Thanks.
Hi StarboardMA and aburgherAU,
Can you please make a token reset to my station to?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
