- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo setup on Homekit - require token reset
I had HomeKit set up but then removed it because I was reorganizing things. Now when I try to add my base station again the app just gets stuck on "Discovering your device. Please wait." I saw this posted elsewhere for a different hub and support sent a token reset request which seemed to resolve the issue for others. Is that what I need here?
Same problem here! Very frustrated with the product. Was trying to reach customer service. Spent almost 1 hr on hold and finally gave up and asked for a call back. That was last Monday. I’m still waiting for a call from Arlo. Not working with Homekit anymore - which was the main reason i bought these cameras. Horrible customer service and product not to the standard I expected for what I paid.
Hi slash128,
Which Base Station/SmartHub model are you having the issue when trying to set up Apple HomeKit?
Hey mkhongk, Michaelheyn,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hi Jessica, it is the VMB4540. Thank you.
Thanks.
Thank you Jessica! The reset token fixed it. I was able to set up Homekit.
Thanks,
Michael
Any luck resetting my VMB4540, Jessica?
Hey slash128,
Hi Jessica, it is working again, thank you. I also have a VMB4000. Should that work with HomeKit? If so, would you please send a reset token to that one as well?
You should be able to set up HomeKit with the Base Station or SmartHub that you have 🙂
Ok, is there something special I need to do with it? When I try to add it I get an error that it is not able to be added. It is on the latest firmware. I am referring to the VMB4000 specifically. The VMB4540 is working since you sent the reset token. Does the VMB4000 also need a reset token, or ?
Make sure to reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I am unable to reconnect my Arlo to Homekit - the process freezes at the detect devices stage. Reading the forums the corrective action appears to be "reset token" on my device. How do I do that? Can it be done remotely by Alro support? Thanks
I was out there yesterday and tried but it did not work. It was still stuck on "Discovering your device. Please wait." Did you send a reset token to the second base station?
Hi,
I'm having an issue setting up HomeKit for my device (VMB4000r3, FW:1.16.3.2_3563_6cd3d19). I've restarted my base station multiple times, but it didn't work. I've seen that the only solution is to get a token reset request. Please help!
Yes, I sent a token request to your second base station. If you're still having issues, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Hi CopilotUK and Stephen_L,
I have been trying to get my Arlo Pro to integrate with Homekit since the beginning to no avail.
If a token reset is what's needed I would appreciate one sent please.
Hi m1jacob and kenfield,
Good Evening, I have a VMB4000r3 and I am in the same boat. Homekit was working, then it wasn't so I removed it. Now when I try to add it back, I am getting the same Discovering you device... Please send a reset to my system.
Hi lupothebutcher,
That worked like a charm. Thanks for your assistance.
Doesn't discover anything for me? VMB4000r3. Worked before then stopped so removed. Now trying to add back. I have taken out power and added back / restarted...
AppleTV
33 -
Samsung SmartThings
86 -
Security System
