For the past week, my Apple Home app has said an Arlo update is available and tells me to use the Arlo app to update. However I see no options for updating within the app. What gives?
5 REPLIES 5
Can you try and remove the app and re-install it.
Remove the Home app or the Arlo app?
You can try to re-install both apps if you like. It sounds like the Home App is the one having an issue.
I included a screenshot in my original post. The Home app is preinstalled on iOS and can't be removed.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
