Arlo you need to sort out your game. This is unacceptable.
I had the same problem and fixed it by rebooting the arlo hub.
ShayneS,
My Alexa announcements are working again. The notification announcements started working early this morning.
Thanks!
Thank you for all your feedback. The notification issue with Alexa and announcing notifications is now resolved. You should not need to re-link any accounts with Alexa.
Are you still experiencing this issue?
When one camera gets set off by motion, Alexa announces "motion detected @ ___ and announcements every single camera I have notifications set for. But only one particular camera sets off ALL the cameras announcements. The cameras do not actually all get set off, just Alexa announces each one in succession after 1 particular camera gets activated via motion.
@Tsmith73
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
I have tried te-setting the base and deleting and reinstalling all the cameras. The same camera (labeled Front Door) will not turn off with the schedule, either. It still motion activates regardless if the the base schedule is "off" for all cameras.
@Retired_Member im struggling to understand what you mean in regards to your issues. Is it announcements your getting via alexa when your camera detects motion with one particular camera. If so have you tried on the alexa app to switch announcements off?
Also Tsmith make sure you dont have any routines set on your alexa app which may be causing this.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
