- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Able to view livestream on Google new smart di...
Is anybody using the Arlo app on any of Googles new smart displays like the Google Home Hub or the Lenovo Smart Display? I am wondering if it works on any of them as Black Friday is coming and I am interested in one as a possible baby monitor. Thanks
Hey @Retired_Member,
I have the Google Home Hub and I am able to stream my cameras live through there 🙂
ok thanks. all i need now is confirmation on the lenovo displays since that is the one im looking at getting.
Looks like a user was able to test their Arlo products while viewing on the Lenovo Google Smart Display. You can refer here: (Lenovo) GOOGLE SMART DISPLAY
Now if only the Arlo Doorbell could push the stream to the display.
If Arlo Pro 2 is working, I wonder if it the problem is only with Alro Pro. Let me know how the 10" does. I really need this to work. Thank you.
Hi all... I am wondering if there is a solution to this problem?
I have 2 Arlo Pro cameras that I want to be able to view on my Lenovo 8' Smart Display. So far, I can view the cams through the Google Home app on my phone, but cant figure out how to get it to show on the Lenovo. Thanks!
giovanni2 are you swiping down from the top of the screen and selecting cameras?
I have been using the Arlo Pro 2 cameras and the baby camera on both the 8 inch and 10 inch display. they seem to work about 50% of the time.
Let me ay this first; I have a 1 gig up and a 1 gig down Internet connection from fios with google mesh wifi routers and i'm getting close to those speeds through speed test. I have a cat 7 Ethernet line running into the back of the arlo base station. I shouldn't be having any issues with lag or connections issues to the lenovo displays but i am.
I think the arlo r&d team needs to be testing these heavily on these google smart displays, they are only going to get more popular in the future.
usually what will happen is once they are playing they will play for a few minutes and then almost freeze and go to a black screen saying "Smart Home camera Control" which requires me to exit of of the camera back to the main screen and try to go back into the camera again.
The other issue I will get is a white screen saying "the stream in unavailable from the desired camera right now"
I have also noticed a 20 second lag on the baby camera.
I no have access to any of the controls or settings for the cameras on either display. you are only able to view the cameras.
Thanks for youe response....
When I swipe down at the top of the screen, all I see is an icon for "Media" or "Broadcast". I do not see anything camera related.
Hi, can you please explain to me how you got the Arlo cameras to show up on the Lenovo Smart Display? I have 2 Pro cameras and cannot figure out how to get to see them on this Smart Display. Thank you!
I am having the Same issue. Arlo Pro cameras, Lenovo smart display. I added the Arlo Account in google home, and all I get is a battery icon with an on/off switch. No video. Voice commands just return an error.
To add the cameras you want to make sure you have the arlo app installed on your phone and set up. to add it to google home, open up the google home app, click the add circle with a plus icon in it on the homepage, then setup device, works with google and go through the list to selct arlo. you will also want to go back once thats done and set up a new deivce which is the lenovo smart display. thats what i can remember. hope that helps you
AppleTV
32 -
Samsung SmartThings
85 -
Security System
