  • 8 Replies
  • 6224 Views
  • 7 In Conversation
Retsalb
---IFFTT ACCOUNT---
My IFTTT account is set up.
I have linked ARLO and all other products to IFTTT acount.
I have downloaded and created IFTTT recipes.
The recipes are turned on and active.
When I "check recipe now" on IFTTT site... "Recipe Checked" and all is green.
---ARLO ACCOUNT---
The camera in the recipe has notifications on
---ISSUE FOR YOU TECH GUYS TO SOLVE (HOPEFULLY)---
When the ARLO camera senses motion... it sends a notification to my phone, but
the IFTTT recipe does not respond.  I then created other recipes... still nothing.  IFTTT currently works with my Iphone 6s, Hue lights, and Piper security system.  They all talk to each other via IFTTT.  So the only player to this party not chatting is ARLO (NetGear ran out of red cups?).
Thank you in advance for the advice... my fellow security party people.
8 REPLIES 8
Just out of curiosity, are all your devices up to date firmware-wise?  Check settings to see if any red triangles exist for any devices.
Retsalb
Went through Cameras and Settings.  Not seeing any red triangles.  Where would they be normally located?  Also, does the IOS app and the web portal differ for how that would appear?  It would be nice if I could easily see what the most current firmware is... and compare that to my devices.
This is what I have for the latest firmware:
Current Wire-Free firmware: 1.2.4941
Current Base firmware: 1.7.3_5005
Current Arlo Q firmware: 1.7.4_5517
You can also check https://community.netgear.com/t5/Release-Notes/bd-p/arlo-release-notes for release notes which will reflect the latest releases.
The firmware update notifications are noted in Settings, My Devices.  If one or more are needed, My Devices will show the notification.  Clicking on that section will show all your devices as well as which ones aren't up-to-date.  Doesn't matter if you use the app or web - the notifications are the same.
kippers
I am having a smiliar issue.   Arlo is triggering on motion and recording, but IFTTT receipe is not running consistently.
burundz
Me too.
TheRealDaali
It is the same for me as well.  I am trying to chain events (motion detected on wireless triggers, recording or arming on Arlo Q) and the recipes are not working.  They set up and check out fine like normal, just do not work.
EdBish
When the ARLO camera senses motion... it records, sends a notification to my phone, but the IFTTT recipe does not respond.  I then created other recipes... still nothing.
ambo33
Reviving a dead thread, but same thing happens to me. Has anyone gotten ifttt to work properly?
