  • 2 Antworten
  • 7816 Aufrufe
  • 2 in Unterhaltung
Dizimach92
Hello, I can not purchase ELITE plan for ARLO. Each time I click on it, I get httpError
this is copy - paste of error, please help
HTTP Status 404 - / $% 7BElite-Month-PlanID% 7D
type Report Status
Message / $% 7BElite-Month-PlanID% 7D
description The requested resource is not available.
Apache Tomcat / 8.0.23 "
2 ANTWORTEN 2
AnnaK
Hi @Dizimach92,
thank you for your Post!
Could you tell us which credit card do you use to upgrade the service plan?
For which country do you want to upgrade the service plan?
The service plans Premier and Elite are not available in all countries. Some countries will only have the Basic plan.
With kind regards,
Arlo Team
Dizimach92
I have few houses, Croatia, Bosnia and Herzegovina and USA.
I would like to connect three base stations into one account so I can see it all. Is it possible ? I tried to purchase from USA IP also but same error.
  • 2 Antworten
  • 7817 Aufrufe
  • 2 in Unterhaltung
