  • 5 Replies
  • 1774 Views
RAB13
As I use Gmail and there is no push function for use on a Mac it can take 15 minutes before an email is notified to me. Is there any way or any future update to have a text warning that is sent directly to the phone?
use a different email server if gmail is causing issue ...
As to a SMS (text) , yes, many phone compaies allow the phone number to be used as email and you get a text
Alltel
[10-digit phone number]@message.alltel.com
Example: 2125552555@message.alltel.co
AT&T Wireless (now part of Cingular)
[10-digit phone number]@mmode.com
Example: 2125552555@mmode.com
Boost Mobile
[10-digit phone number]@myboostmobile.com
Example: 2125552555@myboostmobile.com
Cingular
[10-digit phone number]@mobile.mycingular.com OR
[10-digit number]@cingularme.com
Example: 4152555555@cingularme.com
Nextel (now part of Sprint Nextel)
[10-digit telephone number]@messaging.nextel.com
Example: 7035552555@messaging.nextel.com
Sprint PCS (now Sprint Nextel)
[10-digit phone number]@messaging.sprintpcs.com
Example: 2125552555@messaging.sprintpcs.com
T-Mobile
[10-digit phone number]@tmomail.net
Example: 4252555555@tmomail.net
Verizon
[10-digit phone number]@vtext.com
Example: 555255555@vtext.com
Virgin Mobile USA
[10-digit phone number]@vmobl.com
Example: 5552555555@vmobl.com
5 REPLIES 5
Alltel
Boost Mobile
Cingular
T-Mobile
Verizon
Virgin Mobile USA
RAB13
It will be pretty difficult to change my mobile provider for various reasons.
Many thanks for the information re the phone number as email.
Just remember, the email is sent AFTER the recording is finished and done... ( pushes on android/ios come ate the start of trigger event )
So if you recording is 60 secs long, an email should be 10-20 sec additional only ... if working well
RAB13
If I understand you correctly, the telephone approach that you suggested will be pushed at the beginning of the recording whereas the standard email process is after the recording stops or is it the other way round?
RAB13
I have just spoken to my phone provider and unfortunately this email system for sms and mms is not available in Austria.
