  • 2 Replies
  • 785 Views
phatDidi
Since 11.10 a.m. Sept 28 Arlo not recording to my email.Up until then i was recieving daily motine clips.The camera's are working fine but nothing going to my email.
First , easiest thing to try is do a manual started record ( push record circle when watching live mode ) and make sure that part of the system is working
Second thing to check is if the cameras are still in active record mode.... The "running man" MUST be black for a motion record at your times set
Third thing is to check you email and make sure it's not blocked or filtered
And power cycle the base.
